Stumped.. Please Help!!
I have a 1989 Sportster Deluxe 883 that has been shutting off on me. It has happened 4 times in the past 2 months and so far nobody can figure out why. The Coil, plugs, & wires were changed and the petcock recently cleaned.
All 4 times have occurred within 10 minutes of my starting point and at speeds less than 25 mph. The bike just stalls and won’t restart. All of the lights are on and it tries to start but won’t kick over. Then after a while it starts up like nothing ever happened…
Thanks!!!
Thanks!!!
Have you checked the ignition switch?
Your sporty prolly has a different one than my RK, I'm sure, but...
The contacts inside the switch may be burned, causing the ignition contacts to lose connectivity for an instant. Even if it isn't the problem, if the switch hasn't been replaced in a few years, it's not so expensive that it wouldn't be worth a try.
Another place to look, might be inside the tank. Could the liner be flaking off, and clogging up the fuel filter? Could the lines be bad? I've seen hoses that crack inside, causing a momentary blockage at random times, causing a stall. Replace all fuel lines, another 'not so costly' attempt to find the problem.
Vapor Lock?? This happens to me quite a bit on my DR. Next time it happens, take of the gas cap, put it back on and try to start it.
__________________
General Inquiries:
Info@LongRideShields.com
Sales and Marketing:
Sales@LongRideShields.com
Phone:
775.331.3789
General Inquiries:
Phone:
775.331.3789
Put a clear filter in line. If you see fuel then you know that the tank isn't plugged without just removing the fuel line. If it has gas in the filter and you take the cap off that eliminates vapor lock from the gas cap vent. One spark plug carried in your pocket will check fire without removing a spark plug from a hot head and possibly stripping out threads. You can quickly check fire before the bike cools off and restarts.
Hey - not all that familiar with the 89's but what type of fuel pump do you have? Reason I ask is that I had a similar issue with my Sporty and ultimately found the little screen in my fuel pump was gummed up. I actually replaced it versus cleaning it and never had the problem again. Not sure if that is relevant to your situation or not, but thought I'd throw it out there.
Good luck!
Good luck!
