head gasket thickness and compressoin
hi.
does anyone know, how much the compressoin ratio is changed if a thinner head gasket is used.
I think the standard head gasket on my 88 is aprox 050 thou thick.
I have seen gaskets advertised at 030 thou thick.
so how much does dropping the head 020 thou affect the compression ratio.
thanks.
thanks.
The change in gasket is about 3.6 cc volume in cylinder decrease, so assuming a standard bore and stroke, 3.75 X 4.0 and chamber volume of nominal 85 cc it would work out to about 2 points of compression, ie from 9.0-1 to 9.2-1, if my math is correct.
hi.
thanks.
thanks.
+1 on the BigBoyz compression calculator.
SportbikeCO
Engine Mechanical Topics
16
03-06-2017 09:44 AM
