basket case
basket case
i have been thing of finding a basket case and rebuilding it from the ground up..
has anyone taken on such a task and if so, was it worth the time to do so
Whole lot of factors goes into what you think is worth it , most all my bikes but 2 have started as baskets or in need of major TLC & repairs and I haven't regretted one of them . You learn a lot , pick up some skills , spend money you don't need to as part of that learning thing but when it fires up and rolls out that first time there isn't any better sense of accomplishment .
its lawaays been a dream of mine to do and have know people in the past that have done that type of thing, for me it would be just a hobbie to do and fill in some time
Bikes are torn down for a reason. You will discover the reason when you reassemble it.
If you like headaches, aggravation, frustration and hopelessness you will receive a lot of satisfaction and pleasure at the end of the build.
Don't pay more than 10% of retail for a bike in pieces. Make sure you get a title.
i figure as long as the majority of the parts are there and all major componants are there then, im thinking that a blown motor, trashed tranny, spun bearings,possibly cracked cases and or stripped bolt holes are about as bad as it may et, i could be wrong, the only things i would be concerned about would be would be cracked cases and bent frame.. everythng else im not to worried about
If you had the time, energy and $$$, you could build a bike from parts sourced off eBay I suppose. Knowledge of what is interchangeable would be crucial, though.
Build
I've been thinking about the same thing, buying a basket case. My question is, can i buy a basket case and lets say only use the motor and other parts from the basket, and some parts from another bike and be able to register it?
