what can cause high oil pressure
took out my 09 ultra and notice the oil pressure was up to 60
usually was at 30ish when running and around 5-10 at idle
60 i take it is way too high, did shut it down for a bit and it seemed to be lower
never happened before
comments?
thanks
comments?
thanks
There is a bypass valve. plugged lines or filter maybe, but perhaps the bypass is stuck.
with the Baisley spring I run around 55 so no, it will not hurt things
