Ironhead with 10.5:1 compression
Old 10-17-2013, 12:26 PM
Jamz's Avatar
Jamz
Jamz is offline
Default Ironhead with 10.5:1 compression
Ok guys and gals,
I just read over some of the receipts (from the previous owner) that were supplied when I purchased my bike.
It looks like the bike feels so strong due to some internal modifications.
The bike was modified from 9.5:1 to 10.5:1 compression, larger exhaust valves, stock intake valves, bored intake and throttle body, some gear changes, and some drag pipes.
Are the modifications I have similar to what others have done to their Ironheads?
Old 10-17-2013, 12:31 PM
jwhardin's Avatar
jwhardin
jwhardin is offline
yes. they are. some have done more, some less.
Old 10-17-2013, 12:33 PM
Jamz's Avatar
Jamz
Jamz is offline
How reliable have the bikes been for others?
Anything extra I should do, in terms of engine care, to keep the motor healthy?
Old 10-17-2013, 12:35 PM
jwhardin's Avatar
jwhardin
jwhardin is offline
reliability of a modified bike largely depends on the quality of the parts and installation.
Just keep oil in it and ride it.
Old 10-17-2013, 12:36 PM
jakenok's Avatar
jakenok
jakenok is offline
run good gas, watch your timing. Is it kick only? that should be fun.....
Old 10-18-2013, 01:40 AM
Jamz's Avatar
Jamz
Jamz is offline
Yeah its kick only, but usually kicks over within 5 kicks - sometimes on the first kick!
It runs super strong, but recently developed a leak below somewhere - thinking it might be from the bottom if the generator only tho.
Another thing is that when i shift into fourth gear, on the freeway, the bike starts a rattling sound with light ckinkering noise..... what can this noise be?
Old 10-18-2013, 08:52 AM
jakenok's Avatar
jakenok
jakenok is offline
given the harmonic characteristics of a solid mounted shaker like an iron head, it could be anything. I'd start by going over the ENTIRE bike and checking fastener tightness. **** loosens up pretty quickly sometimes. blue loctite is your friend. If everything is tight, have someone do a visual inside the tranny trapdoor.
Old 10-18-2013, 01:42 PM
rideflhr's Avatar
rideflhr
rideflhr is offline
My '71 XLCH had 11-to-1 stock. It worked fine.
Old 01-15-2014, 04:02 PM
Jamz's Avatar
Jamz
Jamz is offline
11:1 compression on an Ironhead?!
Do you have a sound clip you can share?
I bet it sounds BAD as a MFer
Old 01-15-2014, 05:38 PM
baka1969's Avatar
baka1969
baka1969 is offline
I don't know what the compression is on my IH but if you want to listen click here:
http://m.youtube.com/channel/UCvq_Mg.../videos?view=1
Khshockey44
EVO
03-06-2018 06:07 AM
texashillcountry
EVO
46
12-24-2013 05:33 AM
stng_96
Exhaust System Topics
02-10-2012 09:44 AM
kdietz
05-15-2007 01:07 AM
bjornsson
16
08-31-2006 08:12 PM
Quick Reply: Ironhead with 10.5:1 compression
