sweet custom GoPro handlebar mount
alright so a few things that have been on my mind:
first is that GoPro does not make a bar/pole mount for 1.25" diameter bars which sucks if you just liked to film your rides for fun or art like making a time lapse video of a run as I used to do on a bike with 1" bars
then with all this crazy crap happening to bikers lately such as the NYC Range Rover incident, the Brazilian bike theft attempt, a local kid getting killed right down the street from my home in Phoenix this week on his crotch rocket, and my recent altercation with a Lexus driving deusche in North Scottsdale I feel it necessary to record each and every ride in the event evidence would be helpful
so I started wearing the chesty GoPro mount but found it filmed my gauges for the most part, I rarely wear a helmet (a debate for another thread) so the helmet mount for the most part is- out
after some thinking I decided to order some spare bar clamps from Barefoot ******* (http://www.barefootwillies.com/product-p/ec.htm), one in fact for the cell phone holder of theirs which had the clamp for the old 1" bars and then a second which I thought I could modify to attach the GoPro tri pod mount (http://gopro.com/camera-mounts/tripod-mount) to the handlebars
I paid for expedited shipping and the clamps were here 2 days later, note the tri pod mount accepts a 1/4" standard bolt thread
I picked up a 1/4" by 3/4"L flat head bolt to run thru the clamp, I had to drill the poly-carbonate with a 1/2" drill bit just so slightly so the bolt would rest below the curved surface as not to scratch my handlebars, used neoprene (rubber) washers on both sides of the poly-carbonate clamp to reduce vibration to the camera, I'm pretty pleased with the result
here are some more installation pics, I'll get you some video tomorrow on my way in to work, also note the clip hanging from the GoPro case, here is why that standard lanyard is important
I'm experimenting with a rear view camera as well, tried this helmet mount on the rear pad, camera was super shaky, on a positive note, not one cager got/stayed close behind me once they noticed the camera, tomorrow I'm trying a bar mount around the rear quick release bar for the sissy bar
A word of warning for anyone using a solid Go-Pro mount. I had it mounted on the engine guard and it cracked from vibration fatigue. My Go-Pro Hero II sailed of into the wind at 75 MPH. This was about miles into a trip. It broke just below the center adjustable joint.
dbc that's exactly why I posted Mic's video of the lanyard, I did this immediately after we snapped a mount on our gokart out in the desert, the GoPro plus LCD backpack were gone, luckily we traced our path, in the dark, and found it in the middle of the trail, I just lost a damn lanyard the other day without the GoPro on board so I'll need to pick another one up, lanyards are cheap but save big over replacement cameras
now check this crap out, not one week into filming and I capture this *** almost side swiping me this afternoon on the way home, you can almost make out his plate
here are some further protective steps in the event you get seperated from your beloved GoPro
1) put your contact info in the case physically
2) put your contact info on the SD card
chances are 50/50 as to whether or not the finder is a good person but if you don't supply the opportunity, there is a 99% chance you'll not get your camera or SD card back
why not 100%? well there was a kite surfer who lost his in the ocean, a fisherman found it, posted the images on a forum and someone ended up recognizing the original owner, pretty crazy
Good idea on the lanyard. I've been using one since I hit a rain filled pothole and my GPS jumped to it's death.
I used a small ball mount under the left mirror to mount my GoPro.
No vibration, easy to reach, and I can turn it to face backwards as well.
I use the long mount arm so that the video doesn't show the tach but shows more of the road. I can swivel it in any direction
I need to using just my left hand.
(sorry for the blurry cell camera shot)
