Cam upgrade for my stock deuce
G'day guys, can any one tell me what are the biggest cams I can put in my 1450 2005 twin cam deuce? I don't know where to start but I DON'T WANT TO REPLACE PUSHRODS, VALVE SPRINGS OR LIFTERS.
any help and advice greatly appreciated.
Cheers Lamy
Cheers Lamy
This depends if you want your bike fast off the line, 0 to 60 mph bottom end.
Or you want your bike to have good speed / pick up at 40 to 60 mph , top end.
Also have you change your pipes , or worked on your fuel mix ?
Ur pick of Cams should never go by the what's the biggest. That a good way to really mess up Ur engine, U can over cam any engine
Cams must be matched to Ur total Build and Needs.
U really should spend a little time reading links by doing a search on them.
"How to pick Cams for a Harley".
Here's a good place to start.
https://www.google.com/search?q=nick...e+a+Harely+cam
Once U figure out what Ur needs are then come back and tell us so we can help U better.
Cams to choose
Thanks guy's have chosen to do whole thing going with
S&S 583 easy start cams, TH MAX TUNER, adjustable push rods, and high lift Valve springs, what do you think about this combo? Am I going overboard on this or is this a good combo.
Cheers
Cheers
