In order to put 14 or 16 inch ape hangers on...
all depends but most likely yes. the only reason you change wires, switches and cables is because they're usually too short for the new bars. so, unless your new bars are relatively close in size to your current bars, which is usually not the case, you have to get new (longer) cables and wires.
tlminh
04-28-2016 09:57 PM
