SE Pro Tuner versus Street Tuner and Warranty Issue
Picking up new SGS tomorrow and want to order parts at the same time. In another thread I found out that the Pro tuner ($459.95) is a much better tuner than Street tuner ($249.95) and have no problem with the cost. The problem is in the SE online catalog it clearly list the Pro tuner as a "NO" for retaining the engine warranty (see bookmark below).
I do have the SEST (Super Tuner) on my 09 and perhaps installing that back then voided my engine warranty but I wasn't aware but now I am and don't want to jeopardize the warranty on my new bike. Has this concerned anyone else who has purchased a new bike? What did your dealer tell you? What did you do?
http://viewer.zmags.com/publication/...d#/f935f2bd/28
Buy a Power Vision instead...better flexibility, technical support, and it doesn't stay on bike unless you want it to. If you ever have a warranty issue, you can always flash the stock tune right back into the ECM and MOCO will be none the wiser.
Either that, or find a good HD tech who isn't a dick about such things.
The key words here are "full engine warranty". Some parts of the engine will still be warranted. Certainly the emissions part won't be though. The rest will probably be a judgment call.
I installed the pro tuner on my FLHX with no problems but brought it in for a loud banging noise on hot starts. Turned out that when I installed the tuner the ACR's were disabled. They enabled them back on and never said anything about my warranty or charge me for it. Much more flexibility with the pro, and by the way no decel pop with a canned map from the SE software. I'm very happy with the tuner ...
I installed the pro tuner on my FLHX with mo problems and brought it in for a loud banging noise on hot starts. Turned out that when I installed the tuner the ACR's were disabled. They enabled them back on and never said anything about my warranty or charge me for it. Much more flexibility with the pro, and by the way no decel pop with a canned map from the SE software. I'm very happy with the tuner ...
Where the Harley tuner has the edge is with warranty work. There are more and more dealers who are taking the stance that if you used anything but an HD tuner they won't touch it, some until you take it off and/or the stock map back, and some not at all. If it was dyno'd using an HD tuner, or if you are running a canned HD map, there's not an issue, ever. If I'm at a dealer because I have a problem I don't want to do anything but say "here, fix it" hand them the bike and HD tuner and no hassle.
Not taking ANYTHING away from ANY other tuner, just pointing out what I've seen more and more. YMMV
