Help with Bad Boots
Help with Bad Boots
I bought these boots to wear when I am riding in cooler weather. They looked pretty good and had what looked like a good sole but when I went for my first ride I could not keep my feet on the pegs. I tried everything including pigeon toed knees but they came off the pegs like there was chicken **** on them and I am sure a few of you know how slick chicken **** can be. I could not get home fast enough.
I was thinking on the way home that I could just rough up the new surface and make them stick but now I am not so sure. I am wondering if anybody out there in HD land might have had a similiar problem and has a fix or if anybody might just have some suggestions. My thought now is instead of sanding the sole that I should try some no slip on them.
Amazon.com: TeachersTape ® - No-Slip Tape - No Slip Foam Surface Tape With Permanent Backed Adhesive Pieces/Pad: Office Products
BTW, these boots are ROADWOLF brand. I emailed the company that does the marketing and in spite of advertising that you can "get on your Harley" with these, they haven't bothered to return my email.
Thank for your ideas in advance!
Take a ride out to the nearest Wally World. Go into the shoe section. There they have some small rubber non-slip pads for ladies shoe soles. Very thin, just peel the backing off and stick them where the sole of the boot will fit on the footpeg.
Be sure and clean the sole of the boot good where you intend to stick the pads.
I used to put these pads on my daughter's dress shoes when she was doing the beauty pageant thing. They work really well.
I thought about the non slip option but afraid the adhesive would give way since it would be under constant pressure and movement. Confirmed this with the cobbler.
I guess folks that are smarter than me would have asked opinions on here about the better options on riding boots. It would have been worth another $50 bucks to have them work right out of the box.
Yep, I took the ol side grinder to my brand new boots. Going to try them out today. If it is not good enough at least I will have a better surface for the non slip to stick to.
Thanks again.
Thanks again.
I can't see the original photo. Link not working. But I would either return them, or take them to a cobbler to fit Vibram soles to them.
When my engineers wore out at the sole, took em to a good cobbler for the Vibrams. No slipping now:
Vibram soles are your best bet. But if you want to try something to stick on the soles get a piece of non-slip stair tread material and trim to size. At most hardware stores and they are intended to hold up to a lot of weather and abuse.
your link doesn't work, but in doing a google search, the only thing i can find on their website that mentions 'harley' is the road warrior harness boots, and you can clearly see that the bottoms are smooth (like cowboy boots). there is no way you're gonna get any traction with smooth soled boots. best bet: resole them puppies, if the fit and comfort is any good. otherwise, cut your losses.
