Oil pressure sender thread size
I am in a progress of making my own oil temp gauge, what's the size of the sending unit thread pitch? TC96 motor Thanks!
Check out this Dakota Digital link - 1/8" NPT should confirm your answer http://www.dakotadigital.com/index.c...rod/prd329.htm
The " bushing " is used to adapt the smaller 1/8" male thread to a larger 1/4" port , the gauges themselves are almost always 1/8" male thread .
The sending unit is 1/8 npt, found it! http://www.ebay.com/itm/Dakota-Digit...383278&vxp=mtr
I think they include a 1/4 npt adapter for different application.
Yep, just pulled mine on '04 Dyna to install a press gauge. 1/4 NPT (18 TPI, -4AN). Only know cause I had to go to Lowe's to get a brass pipe plug to eliminate the OEM sender on the adapter block.
Ludwig von Buzzthoven
08-06-2018 07:54 AM
