Grade 8 Hardware - Shocks
Old 03-02-2014, 10:39 AM
garywi's Avatar
garywi
garywi is offline
Default Grade 8 Hardware - Shocks
Installing new shocks and due to the spacers I have to use, I need longer shock bolts. Anyone find the same type that HD uses except longer?
Need grade 8, 1/2" x 3" pan head with torx.
Replacing lower shock bolt on Sporty.
Thanks
Old 03-02-2014, 10:57 AM
Imold's Avatar
Imold
Imold is offline
another old guy
Received 4,613 Likes on 2,725 Posts
It doesn't have to be a torx head. One of my sporties has torx, other has hex head. The rounded torx looks smoother, but to be honest, I never even noticed till this post made me curious, since I seemed to remember taking off a hex head. Hex head might not look as nice, but if you can't find a torx in the right size, a hex or an allen head is an option.
Old 03-02-2014, 01:24 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Grade 8 Bolts
Grade 8 bolts can be had at Ace Hardware in all kinds of sizes.
Old 03-02-2014, 01:55 PM
_Gir_'s Avatar
_Gir_
_Gir_ is offline
Lowe's has some too.
Old 03-02-2014, 02:25 PM
edgeofinsanity's Avatar
edgeofinsanity
edgeofinsanity is offline
As mentioned, Ace hardware is a good source, or if you have a Fastenall location, better yet. Last time I tried to find some at Ace, the grade 8 bolts were that black oxide coated hardware, not ideal. Torx head might be hard to find, and if you are re-using the lock nut, I believe the lower shock is a fine thread, top is course threaded.
Old 03-02-2014, 02:42 PM
hell hound's Avatar
hell hound
hell hound is offline
if they have fastenall in your area that is where i would stop first
just take the old bolts with you and tell them what you what
that way you can match it up pretty good
Old 03-02-2014, 04:30 PM
Crazy Biker's Avatar
Crazy Biker
Crazy Biker is offline
1/2-13 is course threads per inch& 1/2-20 is fine threads per inch.
Old 03-02-2014, 04:50 PM
garywi's Avatar
garywi
garywi is offline
Thanks! The Ace by my house has grade 8 hardware but its all zinc coated tan/yellowish color. i'll keep looking
Old 03-02-2014, 08:04 PM
ALUCARD19's Avatar
ALUCARD19
ALUCARD19 is offline
Check online if your not in a hurry many screw and bolt manufacturers listed online, or try MSC direct that is where I order all my fasteners from for work they ship out the same day and you get it the next day usually before noon.
Old 03-02-2014, 08:10 PM
hell hound's Avatar
hell hound
that is a good idea. If not in a hurry the bolts are waitin for you on your doorstep when you get home
Quick Reply: Grade 8 Hardware - Shocks
