Help with unknow wire
Dear Fellow riders,
Im feeling a little dumb and set back right this minute for after about two hours of searching the net and putting in everything I can think of in the search browser I still cannot find a answer to what I hope one of you can quickly tell me what this wire is.
Ive had this bike since September and I must admit Im sure ive seen this wire before but just didn't stop doing what I was at the time to really look at it. Now this is not my first Harley Davidson not even my third or fourth, there has been plenty but I just don't remember this wire.
2008 Fxstc Softtail custom 96 ci engine, this wire is hanging right under the air cleaner plate and is slightly visible from standing at the right side back of bike looking right in the "V" , this wire looks factory and is capped and has I think it has three wires I can see in the harness, Looking up under and around the cleaner you can see this wire coming down out of the harness form under the tank.
Does anyone know what I might be looking at and why its there, I did notice it has double sided tape stuck on the wire and had been stuck to the back side of the air cleaner plate and I think would have been hidden until the tape let go.
Thanks a lot guys
Jeff
Thanks a lot guys
Jeff
No, I believe he must have the air pressure sensing unit disconnected.
It should look like this:
Unless of course someone removed it. A picture would be very helpful.
Thank you Dbc, I must admit first ive heard of this but glad to know that nothing has come unplugged under there and im fixing to damage something.
Thanks again
Thanks again
Dear Fellow riders,
Thanks a lot guys
Jeff
Thanks a lot guys
Jeff
Mr. Rwhisen,
No sir it doesn't look like that, Its just a common snap in type plug with a cover over it, the wire appears to be shield with either a grey or black cover and you can see three wires right at the plug one I know I saw was yellow.
It is a sensor they unplug from the stock plastic airbox & leave hanging when you get a stage 1 air cleaner, as it's no longer needed. All my bikes have had it.
Ooops sorry wrong picture, didn't mean to confuse you.
Jmbeebe0722
08-17-2013 03:37 PM
