GPS Mount - Front and Center - Ideas
Ram Mounts has a relatively new mount that is designed to go under the stem on your mirror( basically a oval washer with a ball on it). I removed one of the windshield brace bolts and put the mount on the brace. Then just get a arm in a length that will get you close to that position...
Oxforo sells a GPS motorcycle mount that attaches to the handlebar (or something else) that I'm considering getting myself. It comes with a waterproof cover and a hardwire charger for about 20 bucks total.
http://www.ebay.com/itm/Waterproof-G...-/111304751728
Another stem mount - Stainless Steel
Leader makes a mount that is stainless steel, won't rust, won't wear away over time. Mounts to the nut on your windshield brace. Simple GPS option is basically a stem with the ball on the end (common to Garmin GPS). Or you can get a bracket that mounts to the same place (that one is chrome) but accepts ALL their device plates: http://www.leadermotorcycle.com/universal-windshield/
I am working on the same thing. So far I am heading to a solution close to what Hammerhead did except I like to switch between my windshield and my quarter fairing. I am thinking of the same mounts except attaching them to a quick release mount or at least something that is not on the shields. We'll see.
I use this: http://www.ebay.com/itm/MOTORCYCLE-W...f32302&vxp=mtr
You can replace a windshield nut with the mount or just drill a new hole and mount it anywhere on the windshield you want.
