Fairing switch manufacturer?
Morning...
By chance, does anyone know who makes the (OEM) switches for the fog, or driving lights on a '14 SGS?
I am talking about the ones that go in the fairing. Currently there are two cover plates on each side of the ignition/lock, covering three holes each.
I want to know if I can get just the switch(s) for some other equipment.
Any help would be greatly appreciated.
Thank you
FrankEGD
Thank you
FrankEGD
Were you able to figure this out? I saw on another post where you had posted up a pic of your stereo where importing some files and saw some ACC switches on your dash panel.
Do you have a list of part #s?
Thanks
Thanks
Received 13,415 Likes
Most electrical components will have Mfg. info including p/n's on the body of the part (Unless they are custom made for a customer, and then they may have that suppliers p/n etc. ).
Worth a look.
Worth a look.
No, haven't gotten any info so far.
BUT, Harley now sells a dual switch assembly for the '14 FLHX. Part number 71400106, $119
That will give you 2 switches and harness. One of them is for up to 2 amps, the other one has a relay and is for stuff over 2 amps.
And the switch assembly is in a small plastic enclosure, filled with glue. No way to see who makes it or get a part number. It also has a blank cover on one side, in case some bike already has the switch for the driving lights. The switch is build in already, all that is needed is the button part, which is interchangeable.
Just FYI, the harness that comes with this set plugs into the grey 8 pin accessory plug under the left side panel. Like me, I already had a accessory harness plugged into it. Part number 69200722, which was the only one available last year. And of course, that does not work with the new harness any more.
But one can take the new and old connector apart, add the one missing wire from the old harness to the new one, and solder the two additional wires from the old to the new, combining both of them.
If someone goes this route, I suggest using the new harness that comes with the switches, it has bigger wire gauges..
I hope that helps.
Thank you
FrankEGD
ACLazer
03-12-2012 07:15 PM
