Anyone running 42mm mukuni with 95 inch?
If ur running a 42mm mukuni and 95inch I like to here what Jets ur running and what's done to ur bike thanks
Thanks I'm running the 60 a/c pump now and a 165 main with 20 pilot... I moved up to a 95 inch with 2006 heads so I need to rejett... I was thinking maybe a 167.5 jet move it up one jet from what it's at now. I have stock needle in the middle not sure if I should change that too. ..
SE 95" kit
Andrews 37TW cams
Daytona Twin Tec ignition
stock heads
I have a set of 06 heads I'll be putting on in a couple weeks, after I clean the ports up.
Andrews 37TW cams
stock heads
