2013 flhtp front police lights
Switching from stock police lights on the front of my motorcycle to whelen super led par 36 light in the fog light mounts. Problem I am having is the right side is a lot dimmer than the right. It is not the lights themselves as I have tried them both on the left side and they are very bright....Any suggestions on what you guys may think is the problem?
Voltage problem?
Maybe I need a load equalizer?
Flasher module in the front fearing?
Voltage problem?
Put a multi-meter on the terminals and see what you are getting for voltage.
IIRC, the right flashes if the light was incandescent. Police bike wiring gets hacked with all the mods done to lighting.
Should be an on line wiring diagram somewhere.
This might help and get you started..
More searching might bring up a newer bike.
http://www.rbracing-rsr.com/downloads/2008wiring.pdf
car5car
12-27-2009 11:03 PM
