MP3 sound booster "Sound Shocker"
I am running a 2011 version of HK radio with fairing BOOM speakers.
When using my mp3 through the auxiliary jack I get low volume. I have to crank the volume on both mp3 and HK radio.
Searching online I came across this http://phpaudio.jigsy.com/ Sound Shocker pro claims to boost sound from a mp3 4x without needing any power to the device. I have zero audio smarts. Has anyone here ever heard of or better yet used this. Or do you have any better solutions without spending hundreds of $$ on a complete new sound system.
I would suggest looking into a portable amp.
The FIIO amps are great at boosting up portable mp3 players. I have never seen or heard of that one you mentioned.
Stopped at a Bose store yesterday in search of some new headphones to help block the wind noise. They have a new set out that supposedly can do it.
http://www.bose.com/controller?url=/...&Variant=qc20i
For $300 they better rock. They have a 30 money back guarantee so I'm tempted.
In iTunes select all the music files that need increased volume. Then File from the Menu Bar / then Options / slide the Adjust Volume over to 100%. Then re-copy the music files to your MP3 player.
when running an mp3 player into the hd aux jack, there are a couple of things to keep in mind. you are pushing an amplified source into the hk which then amplifies it again. so you need to make sure that neither one of your sources is 'overamplified'. you should not go above 3/4 volume or so on the mp3, which should allow you to run the hk unit below that level as well. too high on the mp3 and your hk will be amplifying the distortion that you are pushing into it. too low and the hk will be distorting trying to give satisfactory volume.
there are several software solutions available to 'normalize' the volume of your mp3's. that way one is not significantly louder than another. i use media monkey. it's free and it works pretty good. it can also be used to transfer your music to an apple product without going through itunes....
Thanks for your replies!
wuaname: Not very loud, Rush with 1.75 baffles
potato potato: I have never used iTunes, but I know my kids do. Maybe I can ask them to help me..
scratch: I will check into the media monkey.
I emailed the maker of the sound shocker and he replied real fast. He said that he offers a 30 day money back guarantee if I am not happy with it. I also ask him if with my setup he recommended the standard at $30, or the Pro at $60. Much to my surprise he said that unless I am really turning up the bass that I should be very happy with the $30 one. So for that money and a guarantee I think I will give it a shot.
The Sound Shocker showed up today and it DOES WORK. It works really well!
It requires no power supply and no charging, just plug mp3 into it and it into the radio. I recommend it highly for $30.
Darrell
Darrell
