Broken in motor seems to like higher rpms??
Old 04-18-2014, 11:40 PM
Ben E's Avatar
Ben E
Ben E is offline
Default Broken in motor seems to like higher rpms??
15,000 miles on FM 107 build. For mellow acceleration I generally shift into 3rd in low 30s, 4th in low 40mph, 5th in mid 50s and 6th @ 70mph. All depends on conditions, how much quick response I need in traffic.
Lately I find myself shifting later and running her in higher rpms. For example, cruising in fourth gear at 50-55mph instead of shifting into 5th. The engine seems to like this.
Wondering if a well broken-in engine might "enjoy" the higher rpms? Not sure if the question even makes sense. I don't have a tach on the RK so I can't be more precise. Maybe I have been babying the engine all along. Any opinions about this? thanks.
Old 04-18-2014, 11:46 PM
ynots's Avatar
ynots
ynots is offline
3rd in low 30s, 4th in low 40mph sounds like lugging to me. Follow your instincts and keep it where its happy
Old 04-19-2014, 12:07 AM
kingomtn's Avatar
kingomtn
kingomtn is offline
loose motors (either well broken in or built that way) are the way to get power.
there is a trade-off of short longevity. Widened clearances reduce friction and incur more movement (or float) of rotating and reciprocating parts. Heavier oil will help delay rebuild. For now enjoy your ride, you know how it's been and what it is now.
oh, I agree with the above thes twins like to be kept in a higher rpm range, designed to work that way and lugging is actually bad for these motors.
Old 04-19-2014, 06:39 AM
monkeyboy22's Avatar
monkeyboy22
monkeyboy22 is offline
Sounds like you are finding the power band in the upper RPMs. Where the power band is depends a lot on cam characteristics.
Old 04-19-2014, 08:01 PM
Ben E's Avatar
Ben E
Ben E is offline
thanks guys. I sort of feel like I have been riding her like a *****. It's not that I have lugged the motor, and there are certainly times when I wind it out. But now I run it much longer through the gears before shifting, and am less prone to shift if I am up in the power band. After a couple of seasons it feels like I am getting to know my machine for what it is. Or at least understanding how the 555s are meant to preform.
mrsnipy
06-09-2014 04:17 PM
RK_2014
10-14-2013 03:47 PM
tpapa
05-29-2011 02:51 PM
jeffreyjames
02-09-2008 11:25 AM
hd1952
Custom Models
06-15-2006 07:06 AM
Quick Reply: Broken in motor seems to like higher rpms??
