Swingarm stand
Lifting it by the swingarm is not going to give you any extra room to remove the turn signals...you need to lift it by the frame so the swingarm drops down.
I built-up a block of wood about 6"x8"x12" (IIRC) to set my '78 XLCH on when I had to remove the rear wheel. I would just pick the rear of the bike up under the fender and set it up on the block.
