Have you ever seen this happen to engine oil ?
This past Sunday I did an engine and primary oil change using Mobil-1 V-Twin in the engine and the 4-Stroke Mobil-1 in the primary.
Since the previous oil change done in October last year I haven't taken my oil oil to AutoZone for disposal.
After draining the engine oil I needed to make space in my HD oil pan to drain the primary oil , and poured some out into a large glass jar.
As I poured it into the jar it looked real odd, then after a few minutes it settled in layers as can be seen in the photo below.
I haven't attempted to confirm that the clear layer at the bottom is water, but what else can it be?
Could the old oil in the sealed HD oil pan draw that much moisture since October last year?
Could this settling happen in the bikes oil reservoir?
https://www.dropbox.com/s/iryipcaiwd...2019.04.07.jpg
Last edited by 1004ron; 04-23-2014 at 09:24 PM. Reason: Having trouble with Dropbox pics
It looks like condensate, but I'm having a hard time believing that so much could condense in the bike or the HD drip pan.
It would have to be from the stored oil in the drip pan. How short were your rides in between seasons? If you rode the bike for any reasonable distance during the winter and brought it up to operating temperature the water would evaporate into the atmosphere. Is it possible the storage container was used previously and flushed out with water?
My thoughts are that it's the oil stored in the drip pan since October that drew moisture, but hang, that's a lot of moisture to be drawn into a sealed container.
My concern is, what if this happens in the bike - the first fluid drawn into the engine from the reservoir might be water with no lubrication properties.
Most of my mileage is to and from work, which is a 38 mile ride each way, and most of that is at 75 mph on the highway.
The glass jar was 100% dry and the drip pan I bought new.
By the way there is a product called Cam Guard which some people use in their airplanes which is similar to AVBLEND. They also have a formula for cars, boats and small engines. I bet that would work in Harleys.
No way that much built up over a winter in a sealed system sitting , somehow somewhere it got introduced after you drained it or was pushed in during a pressure wash or something like . Even a bike been sitting out in the weather for years never seen anywhere near that amount of water in the oil , we are talking teaspoons at best .
First time I saw that it freaked me out--, my old mentor Pops set me straight on what was the problem.
RIP my old friend - I'm still passin' out your superb knowledge.
