Performance Machine 4 piston calipers - Which brake pad?
About 2 years ago I installed Performance Machine 4 piston calipers on the front of my '09 Street Glide. (left and right) They were the direct bolt on model.
Anyway, it's time to replace the brake pads and their web site is so difficult to use and understand, I can't figure out which pads I should use for my calipers. They offer no support or contact info either. Just have to go through a dealer who are often clueless.
So wondering if anyone knows what pn is the proper one for replacement brake pads for my 4 piston PM calipers?
http://www.performancemachine.com/mo...ent-parts.aspx
Order the pads according to the model # of the calipers, and use the sintered pads with stock rotors.
Try this site and match the pads with what you have , use it as a reference to order from a state side seller
http://www.wwag.com/cgi-bin/WebObjec...&page=%2150763
There is no part number on the caliper itself? Have you removed one from the fork leg? Ditto on the suggestion that you match your pads with ones that are inexpensive and readily available. I believe PM has a Blog on their website.
Not trying to be a smartass but all the info you need is on the site.
You're not being a smart ***, but you must be a lot smarter than me. Because I can not find anywhere on PM's website, that says, exactly what pads to use on the bolt on 4 piston caliper for an '09 Street Glide. If you could point it out, I'd be forever grateful.
Try this link and match the caliper you have , in the description there is the manufactures part number listed . Gonna have to a little looking is all . I'm betting you have these calipers 0052-2413-P and the pads are for these calipers in PM's site 125X4R, 137X4B . Make a phone call they will tell you
http://www.jpcycles.com/motorcycle-b...aliper&Ntk=All
Thanks TwiZted for helping me with some leg work. It shouldn't be this difficult, granted, I should've known my part number for the calipers, but it's silly the pn's for the calipers aren't listed on the PM web site.
