Rachet strap to fork sliders or triple trees?
Old 05-08-2014, 08:35 PM
Hepper's Avatar
Hepper
Hepper is offline
Default Rachet strap to fork sliders or triple trees?
I know theres a million threads about this, but I just need a quick answer from someone knows. I loaded my bike into my pickup and all I need to know is if it's better to strap the front end down on the sliders so it doesn't compress the springs, or around the forks above the trees?
Old 05-08-2014, 08:40 PM
Ragtop's Avatar
Ragtop
Ragtop is offline
Received 1,011 Likes on 576 Posts
I normally strap it to the sliders,where the fender connects, just don't use the handlebars!
Old 05-08-2014, 09:47 PM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,458 Likes on 755 Posts
Dealerships haul bikes all the time, So I asked how they do it. With the bike on its kick stand, They connect the left side strap to the frame and remove all the slack but do not tighten. Attach the right side strap to the frame and ratchet it until the bike is upright. this puts the forks compressed the correct amount. my RK has a place between the down tubes to attach the S hooks. Hope this helps.
Old 05-09-2014, 01:24 AM
2AMGuy's Avatar
2AMGuy
2AMGuy is offline
Received 2,453 Likes on 1,587 Posts
I've found the best point is where the engine guard mounts to the frame.
One on each side and then ratchet down.
I had the Kuryakyn chrome, tie-down hooks that mount to the front forks on my old bike and I've got a new set to put on my bike this week.
They look cool and they're super easy to use.
I also plan on buying two sets of the H-D tie down straps with the safety spring that prevents the hooks from bouncing loose if you get too much slack in the strap.
Old 05-09-2014, 01:34 AM
upflying's Avatar
upflying
upflying is offline
Received 25,977 Likes on 11,032 Posts
Just don't use hooks from the ratchet strap on the bike. Attach the hooks to soft webbing attached to the bike.
I use the triple tree and the top of the shock mounts on my Super Glide when tying it down.
These are the "soft hooks".
http://www.cyclegear.com/CycleGear/A...15_59409_50199
2deuceguy
03-20-2017 12:32 AM
rapp76
01-06-2017 01:46 AM
dudeboy72
09-01-2013 07:44 AM
beau_cauchemar
02-17-2013 09:11 AM
Scout
03-03-2006 08:09 AM
Quick Reply: Rachet strap to fork sliders or triple trees?
