What should SE High-flow oil pump oil pressure be?
Old 05-10-2014, 01:55 PM
KCelectraglide's Avatar
KCelectraglide
KCelectraglide is offline
2nd Gear
Default What should SE High-flow oil pump oil pressure be?
Hi, I recently had my local HD dealer install the Screaming Eagle hydraulic cam chain tensioner and high-flow oil pump upgrade kit on my 2002 Electra Glide Classic, Twin Cam 88 (FLHTC). Due to the concerns with the failure of the old Spring-loaded cam chain tensioners. My question is, does anyone know what the new "normal" oil pressures should be? My dealer seemed petty "unsure" what they should be. At Highway speeds after a hot motor my oil pressure is 52 psi, prior to the new high-flow oil pump is was around 32 psi.
Thank You,
Kyle
BenBoosted
Engine Mechanical Topics
18
03-28-2022 09:24 PM
KCelectraglide
05-22-2014 08:00 PM
KCelectraglide
Oil Archive (no new posts)
05-11-2014 03:53 PM
BenRK05
03-13-2014 06:06 PM
ron bayless
Exhaust System Topics
06-16-2009 04:29 AM
Quick Reply: What should SE High-flow oil pump oil pressure be?
