How can I clean the hazey film in my lights
I have a 2011 Electra Glide with a fogy hazy film inside of my headlight and the 2 smaller spot lights. How can I clean them?
Received 47,787 Likes
Do a search ... There are a couple of threads on this ... I believe that the "solution" is vinegar water and a splash of ammonia ...
kinda hard to get all that compound and wax all cleaned up inside the headlight
Uncle Larry is right... but you have to pull the Hal Bulbs out and with a long cotton Swab,, go thought the hole and Clean the lens from the Inside.....
mine had done the same as Most others have.. I don't worry about it as it dosen't seem to make any diff in the light output....
Alway remember a Google Search is worth a Thousand Post in here.....
Rubbing alcohol. Take light apart, pour a little into the light. Swirl the alcohol around inside the light then empty it out. Cut a strip of good clean cotton from an old t-shirt (about 1"x4", larger for the main headlight) and carefully swab the inside out to get it good and dry. You can use one of those long wooden stick type q-tips to move the cloth around inside the lamp.
do mine with a new microfiber cloth and windex. Cut some off a corner and stick the cut off piece in the light. Get what I can with my fingers and a popsicle stick to get the rest .
