dyno'd the bike
dyno'd the bike
I've been running the Revolution performance ems system, an auto tune system that doesn't require a dyno tune. You send them your ecm and they make corrections based on a number of specs from your bike, and they install theoretical VE and timing tables, and using wide band O2 sensors, the bike will auto tune itself. I worked fairly well, had a pull done, and it was 105 and some change with 110 TQ. Mileage was good 38-40, and granted the bike did run acceptable. but lately I've had some decel backfiring, and some slowness at lower rpms, and I was just getting unhappy, knowing how I built it, It should have had better numbers with better performance. Not a numbers bragging guy, (My HP is bigger than yours!!), but my butt dyno wasn't giving the green light to my riding. So I went to a place here in san diego, and had it tuned, got it back today and it really runs leaps and bounds better. Low rpm acceleration is a huge difference, bike runs smoother all thru the power band, and is really a lot faster. Don't have any gas mileage numbers yet, that will come this weekend. but , even though the dyno is done, the auto tune is still functional, and will continue to make adjustments from the baselines my tuner set. very happy overall, heres my sheet:
Those are good numbers. I have a power vision with autotune pro. FM107 kit installed last year, never had dyno tune and it runs like a top. I wanted to do a dyno pull this year but worry about the outcome. If it is less than what I expect, another disappointment lol.
Charlie
Good numbers you got there. I've always wondered how the EMS would stack up against a actual tune. Did you have to buy another tuner in order to get the dyno dun? From what I understand about the EMS you can't tweak the tune yourself you have to send the whole ecm back to revolution performance correct?
I don't want to rain on your parade, but your dyno graph does not look right. In a properly formatted dyno chart, HP should always be higher than torque above 5252 rpm. This is because a dyno can only measure torque. HP is a mathematically derived figure. The formula is: HP= RPM x Torque and then that figure divided by 5252. That's why they cross at that point.
I'm glad that your bike runs better, but I question the validity of the dyno graph based on the above. Did they give you an explanation as to why the chart is not in standard form?
Received 70,161 Likes
