Scavenger oil change system
I just changed my oil on my 08 roadking with the scavenger complete oil change system
all in all it works as advertised just be sure you tighten the puck up enough or a mess will result, my bad but it still worked oil is clean all through the motor
was worried because I have a JEGS oil cooler setup on my bike but that shouldn't be a problem,
so all i can say is a non mechanic like me can do it,anyone can!!!
I've been using the scavenging system on my Heritage since I bought it. I get a quart of dirty oil out of my motor by using it.
A 'regular' oil change is 3 quarts. A scavenged oil change is 4. If you want to leave an entire quart, or 25 percent, of dirty oil in your motor, that's your choice.
I ride the bike at least 10-15 miles to warm it up, pull into the garage, pull the drain plug and oil filter, then go do something else for a while. Come back, put in plug (with new O ring), install new filter, put in four quarts of oil. Run it for a couple minutes to circulate the new oil and check for leaks. That brings the oil level to just under the full-hot mark on the stick.
Of course, that probably leaves a few ounces of old oil in the motor, but I got 130,000 miles out of my last Roadglide without any internal motor work, 120,000 on the FXR before that. Both still running strong when I sold them. Done it that way for the last 30+ years, six Harleys and 400,000 miles. Good enough for me.
Harley actually has a nice filter drain that slips under the filter housing, but I never thought to run the bike with the filter off until the fresh oil came out.
Doing that only purges the short run from the tank to to filter, but not downstream of the filter, but more important you have no oil pressure to the crucial parts of the motor while doing that.
The following 2 users liked this post by 1004ron:
Halojumper (11-11-2021),
LenBoyLo (04-05-2020)
when i change my oil, i change it into a graduated bucket. i get 3.5 quarts out. i put 3.5 qts back in. how is that leaving 25% 'old' oil in there?
