Brembo rotors on an 06 Ultra???
Old 07-01-2014, 02:44 PM
moparnut426's Avatar
moparnut426
moparnut426 is offline
Default Brembo rotors on an 06 Ultra???
Can I put the 11.8" rotors on my 06 Ultra that runs a 11.5" rotor?
I know the contact area will be deeper, and I dont think the rotors will rub, but Im just sick of the rotors warping. Im changing the front wheel to a nice laced rim, and while I have it off Id like to change over the brakes to the new better rotors.
Kasey
Old 07-01-2014, 04:23 PM
DresserDude's Avatar
DresserDude
DresserDude is offline
Kasey, just do the Brembo calipers too while you're at it and be done with it.
Old 07-02-2014, 11:09 AM
moparnut426
Well I might end up doing that too, but Im just gonna see if these fit. Local HD shop are buddies of mine and had a take off 08 street glide wheel, so I bought the brembo rotors. THey are only like 1/8" or less different and there is like 3/16" or more clearance on my caliper mounts, so if they fit later on I can just put the brembo calipers.
If these rotors don't work the HD shop told methey would take them back and just sell me the OE rotors.
Unless I find the calipers too.
Kasey
Old 07-02-2014, 11:16 AM
moparnut426
Can I put these on and not change the lines, and master cylinder?
http://www.ebay.com/itm/GENUINE-2011...9657ac&vxp=mtr
Thanks
Old 07-02-2014, 01:29 PM
DresserDude
Thanks
There is a good thread on this somewhere. As far as the front wheel, you'll have to make sure about the axle and whether or not the bearings are ABS or Non ABS bearings.
Old 07-03-2014, 06:33 AM
'05Train's Avatar
'05Train
'05Train is offline
Thanks
Was '06 DOT 4 or DOT 5? Brembos have to run DOT 4. Without going to my notes, the only other issue you'll have with the lines is the size of the fittings at the end. I needed to get a custom line for my 'Train to adapt the Brembos to the FXDX master cylinder I used.
Old 07-03-2014, 07:49 AM
hdbob2006's Avatar
hdbob2006
hdbob2006 is offline
I have an 06 ultra-it uses dot 4.
Old 03-11-2015, 07:03 PM
NAILIT RK's Avatar
NAILIT RK
NAILIT RK is offline
Why do the Brembo Calipers need DOT 4 fluid? (I understand you cant mix the 4 and the 5) Can I flush the dot 5 out of the master cylinder with some solvent?
Old 03-11-2015, 07:24 PM
willy_b's Avatar
willy_b
willy_b is offline
6th Gear
I have a set of stock brembo calipers off a 2012 with less than a thousand miles on them Id sell if your interested.
Old 03-11-2015, 07:53 PM
NAILIT RK's Avatar
NAILIT RK
Sorry *****, just bought some off ebay earlier today thanks
lp77
10-11-2016 02:09 PM
FatboyDilbert
06-17-2015 05:40 AM
HGM
EVO
26
11-23-2013 06:34 AM
sharkey
07-14-2012 01:19 PM
loup1276
06-17-2010 07:19 PM
Quick Reply: Brembo rotors on an 06 Ultra???
