rocker c ingition conversion
Hi everyone, just finished converting the ign. on my rocker. I have read quite a few posts on the subject and they all seem to use a different dash and speedometer which can get a little pricey. I used the stock rocker dash and found that the turn style switch would fit with no problem...you
have to machine the hole in the dash for the switch to fit in and make a mount for it but the end result looks like it's supposed to be there.I used a
coil from a 09 soft tail which will plug into the stock wiring ....made a bracket for it that uses the original coil mount as is and thats it, cost on the parts was about 150.00 or so....
-Joe
-Joe
