tssm to tsm i thanks to whoever posted this procedure
Old 07-10-2014, 08:18 AM
82flh's Avatar
82flh
82flh is offline
Default tssm to tsm i thanks to whoever posted this procedure
My 07 Fatboy was a pain in the *** with that super stupid tssm I bought this bike factory new and it sucked!....I bought to standard tsm units for 40 each from Harley (take offs)...I followed this dudes instructions and to bike fired up runs great ! I feel an obligation to thank whoever originally posted this it was helpful and saved me bout 150 buks trailering it to the stealership...thanks bro!....anyone wanting to dump that stupid tssm buy a tsm and follow these instructions...do the procedure 3 times and your running fine!
Completely Disabling Buttonless Fob Security Systems ('07 up)
Forums
Today's Posts
Log In
Register
Home / Ignition/Tuner/ECM/Fuel Injection
Page 1 of 2
02-12-2011 11:34 PM by Nexus9
For those of you do-it-yourselfers out there (like me) who don't want to have to make the trip to the dealer every time they want something done, let me relate my experience with removing the TSSM non-pushbutton security system on my '08 Ultra. This may work for other bikes, but I'm not a factory mechanic - so I can only confirm that this will work on '07 and later touring. One of the advantages of doing this yourself is that you can keep your original module (along with a printout of this post) and re-install it at any time without another trip to the dealer, or if the bike's new owner wants a security system.
The factory security system is contained within the Turn Signal Module (TSM), which becomes a Turn Signal Security Module (TSSM) when it is so equipped. If you are disabling the TSSM (do NOT want a security system on your bike) then you have a TSSM installed now, HD p/n 68924-07. This is a roughly cone-shaped device in a black plastic case, mounted vertically under the seat and to the right (starboard) side. Mine was held down with a silver metal clip. The first thing we need to do is replace this item with a NON-security equipped TSM.
So before you go hunting for the TSSM on your bike and removing it, buy the part you're going to replace it with - in this case, HD p/n 68920-07. They are $114 new from Harley, but I found many on eBay and bought one for $24.95 including shipping to my door. You will also need (highly recommended) a 2 amp (or so) motorcycle battery charger to complete the job safely.
Okay - now, we have everything we need to do the job completely. Find the TSSM under the seat of your bike, remove the clip, and lift it out. There will be TWO connectors plugged in to it; remove both. Note that one of the plugs is larger than the other - this is the input, ECM, and turn signal connector - we will use this again. The smaller plug is the output for pager and siren - tape that one up to protect it and set it aside for now. Plug the larger plug into your new TSM, and slide the assembly back into place, carefully storing the loose connector where it won't rattle or take too much wear.
Whoa. That's it?
Nope. If you try to start your bike at this point, it will rumble and die, and you'll be cursing me for life. The bike knows that the security system has been compromised, and is trying to protect you, the owner. Getting it to feel all warm and fuzzy about its new body parts takes another half an hour - which kind of discourages the swap-out-and-quick-getaway-routine by a more unscrupulous rider who just happens to be enamored with your new paint job.
In the next step, we're going to have the bike's ignition (and lighting) on for more than half an hour, so here's the part where we plug in a 2 amp battery charger to keep things live. With the battery charger hooked up, perform the following:
1. Be sure the ignition has been OFF for 15 seconds or more before starting the procedure.
2. Set Run/Off switch to RUN.
3. Turn ignition key on, do not start. Verify that the Check Engine Light and Security Light come on, and wait for them to go out.
4. Attempt a normal start with the Start button. Engine should come to life and then die. The Check Engine Light should light up and stay on.
5. Wait ten seconds. The Security Light now comes on. The ECM has now entered communication mode with the TSM for the next ten minutes. Look at your watch and do something else for the next ten minutes, but don't shut off the bike, let the battery die, flip any switches, or unplug anything electrical. Just polish the fenders or something.
6. In ten minutes, the security light will turn off. Within 15 seconds, turn the ignition key Off and back On. This Off-On motion should be crisp, completed in two seconds or less. The Security Light comes back on, and you have another ten minute wait.
7. When the Security light goes out again, repeat step six.
8. When the Security Light goes out this time, do the Off-On thing, then when the Security Light comes back on again, shut the ignition OFF. Wait at least 15 seconds, during which time you should be (carefully) unplugging your battery charger (unplug from the wall outlet, then from the bike, right...?).
9. With 15 seconds or more gone by, turn your ignition on, confirm the Run button, confirm neutral, and start your bike. You've created a happy marriage between your ECM and the new TSM, and you no longer have to worry about having a key fob or memorizing a security code. Now you can just worry about someone riding off with your bike whilst you're suckin down a brew in the local pub - use the fork lock!
If you're like me, you'll never remember all this two years from now when you're selling your bike, so print this out, take the battery out of your key fob, and put the fob, TSSM, and this paper in a ziplock bag and store it wherever you would go to look for it two years from now. Happy riding!
SaddleBronc (05-18-2021)
Old 07-10-2014, 02:14 PM
nytryder's Avatar
nytryder
nytryder is offline
I think it may be time for finding yourself a hobby...
Old 07-10-2014, 02:43 PM
82flh's Avatar
82flh
82flh is offline
I think you can f*** yourself
Old 07-11-2014, 08:11 AM
Nexus9's Avatar
Nexus9
Nexus9 is offline
Thanks 82.
And NytRyder, I already have a hobby. Riding, and helping other riders out with clear, complete, easy to follow instructions; instead of the normal garbled, incomplete rhetoric that many people offer as "help" on certain forums.
Glad you liked it!
Old 07-11-2014, 10:29 AM
82flh's Avatar
82flh
82flh is offline
Nexus9 we need more real bikers like you brother you saved me a trip to the stealership and saved me driving 2 hours each way renting a trailer..plus whatever Harley would a charged if your on Facebook add me I'm Camden iron works...your a great guy thanks again...PS who's this NightRider ********?...another keyboard biker I bet..
Old 07-15-2014, 07:26 PM
Nexus9's Avatar
Nexus9
Nexus9 is offline
Nah... that's just his way of joking around - no harm intended, I would think. Don't let stuff like that on the forums bother you.
Thanks for letting me know about your TSM, glad it worked for you.
Old 07-15-2014, 08:44 PM
teampiney's Avatar
teampiney
teampiney is offline
Just snagged a TSM off ebay for 39.95. My only question is if you err during procedure, what happens? Does it revert to original TSSM again?
Old 07-17-2014, 12:25 PM
Nexus9's Avatar
Nexus9
Nexus9 is offline
If you install the TSM and err during the mating procedure, your bike will not start. Shut the bike off, wait 15 minutes, and start the procedure again.
A TSM is mechanically and electrically different from a TSSM, so it will not revert back - the ECM (Engine Control Module, or computer) knows that this not the same unit it was mated with before, and it will not allow the bike to start as a theft protection behavior.
Old 07-17-2014, 12:26 PM
Nexus9's Avatar
Nexus9
Nexus9 is offline
If you have not completely mated the new TSM, you can always re-install the old TSSM if you run out of time before today's ride.
Old 07-18-2014, 08:34 PM
teampiney's Avatar
teampiney
Thank You Sir. That was what I hoped.
Quick Reply: tssm to tsm i thanks to whoever posted this procedure
