Primary Oil Fill Level???
Ok, so the Service Manual for my GF's 2009 Softail Deluxe calls for 32 oz of fluid in the primary after service. This is a stock 96 in motor.
The Service Manual for my 2010 StreetGlide calls for 38 oz of fluid in the primary after service. This too is a stock 96 in motor.
Same motors, same primary case, same transmission.
Why the difference in fluid capacity? This is driving me nuts and I cant seem to get a straight answer from any HD techs. Most common answer is fill to where you can see the fluid just at the bottem of the primary opening.
What say you?
What say you?
Does this have anything to do with the fact the Softail is counterbalanced (the B version) while the StreetGlide is not (the A version).
I am with you on following the manual's direction but this has often concerned me when I service both of them together.
Any other thoughts?
thanks
Received 4,307 Likes
Isn't the softtail a "B" engine and the Streetglide an "A" engine? If so they aren't identical. Bottom of the clutch basket is sufficient.
The primary cases are completely different between the Softails and the touring bikes. As it is, I never measure the quantity, I fill the primary to the indicated level as shown in the service manual.
The primaries have been different before the softail went to a counterbalanced configuration. There were Harley's being built before hd started making the softail b motor, lol.
Sierra Nate
07-13-2019 10:03 AM
