2012 flhx vibration
Old 08-25-2014, 07:42 PM
Jig nut's Avatar
Jig nut
Jig nut is offline
2nd Gear
Angry 2012 flhx vibration
Wonder if annyone found a solution for
The vibration that happens between 2500
And 3000rpm
That feels like road vibration but the road is
Not the cause
Already check for annything loose... Motor
Mount.. All brackets and all bolts I could put
My hands on
I know from reading the forum that others had
The same problem but did not see
Any solution yet.
This vibration is not part of the normal
Vibration the bike had when new.
Old 08-25-2014, 09:36 PM
Panchorelly's Avatar
Panchorelly
Panchorelly is offline
Seems like you should take it in! Clunk and a vibration not normal.
Old 08-26-2014, 01:23 PM
Jig nut's Avatar
Jig nut
Jig nut is offline
2nd Gear
Wow! Your helpful!!!
Never mind I found the problem, runs like
A kitten now... Like it should
Old 08-26-2014, 01:25 PM
rapid49's Avatar
rapid49
rapid49 is offline
So what was the problem ?
Old 08-26-2014, 01:27 PM
monkeyboy22's Avatar
monkeyboy22
monkeyboy22 is offline
His Haiku was too long.
Old 08-26-2014, 08:44 PM
Jig nut's Avatar
Jig nut
Jig nut is offline
2nd Gear
Problem was with the muffler rear
Sliding bracket.
Had to push in the muffler a bit to give more
Play on the sliding bracket.
Was hitting against the end of the bracket
Causing a vibration and also a clunk noise
When hitting a bump in the road.
Simple fix but got me worried it was
Something worst.
You can't run to the shop every time something
Comes up that's why I joined
The forum for ideas
Thumper26
11-04-2012 10:07 AM
djbarker
07-07-2011 09:02 PM
ovalracer
06-14-2009 09:06 PM
GliderXXX
10-27-2008 05:11 PM
txultra
04-06-2006 08:40 PM
Quick Reply: 2012 flhx vibration
