throttle/clutch issue
Old 08-28-2014, 05:22 AM
johnv50's Avatar
johnv50
johnv50 is offline
Default throttle/clutch issue
I have a 2002 Fatboy, and just changed the engine and primary to regular synthetic Mobil 1, 15/50, the car oil not the motorcycle type. Now what is happening is that when I pull in the clutch the rpm's do not go down to idle right away and stay at whatever rpm they were at. Could this be caused by the oil I put in the primary ? Are the clutch plates not disengaging properly ?
Old 08-28-2014, 06:00 AM
HDmikie's Avatar
HDmikie
HDmikie is offline
Well, there's one way to find out. Drain your primary and try a different oil. FWIW, I also have a 2002 Fatboy and just run regular Valvoline 10w X 40 Dino oil. Just make sure whatever oil you use doesn't have any friction modifiers in it. JMO
Old 08-28-2014, 07:37 AM
peg20's Avatar
peg20
peg20 is offline
Can you sit at lights with the bike in gear but the clutch level pulled in? Can you walk the bike forwards and backwards with it like that too? If so, then the clutch is unlikely to be dragging.
Old 08-28-2014, 07:55 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,512 Likes on 3,770 Posts
Has nothing to do with the oil. You do not say if it is FI. If carb, something is binding your throttle cable. FI could be same thing but there are other things on an FI it could be.
Old 08-28-2014, 08:17 AM
johnv50's Avatar
johnv50
johnv50 is offline
Default idle issue
yes it is FI, I adjusted the cables at the throttle, but that did not help. I am removing the tank for a paint job and will check the cables at the throttle bodies to see if there is anything dragging there.
thanks johnv
Old 08-28-2014, 10:21 AM
Jackie Paper
This may help
Attached Thumbnails throttle/clutch issue-throttle-cable1.jpg   throttle/clutch issue-throttle-cable-3.jpg
Old 08-28-2014, 04:02 PM
johnv50's Avatar
johnv50
johnv50 is offline
Default Idle issue
Thanks for the info ripsaw, will check adjustments when I have the tank off
Gwaxley
12-17-2017 11:35 PM
aoehero
Oil Archive (no new posts)
06-16-2011 09:44 PM
CT-Bagger
09-25-2010 06:01 AM
JazzPn
07-02-2008 06:12 PM
GeneFLSTC
09-15-2006 04:15 PM
Quick Reply: throttle/clutch issue
