How do these temperatures sound?
I have just about completed the mods on my 2012 Harley Heritage Softail Classic. I was hoping to cool the bike down from the lean stock setup. I installed the following:
1) a FL-XIED-10 fuel enricher.
2) a K & N high flow filter (same shape as stock)
3) a Rush 3" slash cut slip-on exhaust with 1 3/4 inch baffles
4) a Vance and Hines FuelPak 3 fuel management device - I flashed the map for 3" V&H slip-ons with standard baffle (the closest fit I could find for my exhaust).
The V&H FP3 has a sensor function that let's you view various data, including engine temp. Here is what I got at 93 F outdoor temperature on a summer day.
260-265 F engine temp at 70 mph
386 F after riding for 20 minutes and letting the bike idle for 15 minutes
The engine oil temp (measured with a candy thermometer in the oil filler neck) after turning the bike off was 225 F.
Do these temps seem about right or are they excessive?
Thanks,
Wayne
Thanks,
Wayne
...260-265 F engine temp at 70 mph
Do these temps seem about right or are they excessive?...
The idle temps? Well, I'm not sure because I never let mine idle that long.
But for what it's worth, Harley has (or had anyway up until a couple years ago) a test facility at the Talladega Superspeedway in Alabama and would run their bikes lap after lap. Then, with the bikes idling, place them in a small enclosure (four metal sides but no roof) and let them idle until they ran out of gas.
While I wouldn't necessarily do that to my own machine, those Talladega guys would punish a bike far beyond what most reasonably sane riders might try...then take them out and beat on them some more.
my engine temp at 70mph constant it's around 247°F. When idling the temp skyrocket up quickly, but I turn my FCS on when I hit 300° (measured with powervision); 386° would start having me wanting to turn the bike off or up to 70mph to cool it down .
225°F oil seems very cool for an FI bike, especially in such a hot day. I can only get that in winter, in summer after a ride and a bit of stop and go trafffic I struggle to have the oil below 250°F. Which isn't a problem since I ride a good synthetic (Amsoil).
I don't understand why you'd keep the Xied with a fuelpack though....
for what it's worth, it says in the manual of my 'other' bike, not to let it idle for more than 10 minutes or severe engine damage may occur, and that is liquid cooled. It has certainly been hot, as I went through London the other day and there is no room to filter a bike that size through the London streets, and the first thing to suffer heat damage is valve springs, and it now has a sticky exhaust valve. Go figure.
It's an air cooled motor. Not much you can do about the temperature outside of what you already did. Playing around with the air/fuel mixture. That's about it.
I shut my bike off when sitting at a draw bridge or anything more than a stop light. Sitting still idling isn't parade mode. any movement that circulates the air across the engine fins is beneficial. The speed of the air moving across the motor makes no difference. So as long as the hot air is being moved from in between the fins and replaced with cooler air. The fins act just like a radiator. Sitting still and idling, unless in a cool steady breeze, is a no-no in my book. I shut the motor off.
