spitting sputtering. map code 0180
Old 09-03-2014, 01:29 AM
casty290's Avatar
casty290
casty290 is offline
Stage I
Default spitting sputtering. map code 0180
Hey guys. I have an 04 Electra Glide that has a big bore, Reinhardt true duals, KN air filter and a Harley race tuner. In Sturgis this year I popped a code 0108 MAP sensor. it ran fine up until we were riding through town.every stop it had a high idle when we get out on the highway it started spitting and sputtering. I spent a lot of hours trying to figure this problem out. So far, I have changed the map sensor, fuel filter, put a new air filter in it, swapped a coil, changed injectors, spark plug wires, new spark plugs, checked for a pinhole in the fuel lines in the tank, put a gauge on the fuel system while running and stays at 60. I've looked for loose connections. I did notice the negative battery cable was loose at one time and melted the negative post a little, tightened it up and still no change. I've checked pins on the harness, and have checked all my fuses. I'm lost. Any idea s would be greatly appreciated.
Old 09-03-2014, 06:35 AM
oct1949's Avatar
oct1949
oct1949 is offline
I see two items for a 0108 code..
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
soft 02
06-24-2012 09:31 PM
hardknox
11-29-2011 11:13 AM
Griff012FLHX
07-10-2011 01:22 PM
DocDyna
Exhaust System Topics
08-18-2009 08:58 PM
dennish
12-29-2007 03:18 PM
Quick Reply: spitting sputtering. map code 0180
