Now what???
Old 10-31-2014, 04:16 AM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
Thanks. I have looked at many of these things but will look again.
Old 11-03-2014, 09:10 PM
chicken strips's Avatar
chicken strips
chicken strips is offline
I've had suspension squeak / chirp. Take some spray lube and go nuts, maybe the noise will disappear
Old 11-04-2014, 08:30 AM
nutoy's Avatar
nutoy
nutoy is offline
Default the noise
I have worked on cars for long time and these type of problems can drive you nuts.Most is the time it is something stupid that you would not have thought could make noise.You could try running it with one plug wire off at a time to see if you can make the noise go away,or check the spark plugs to see if you have carbon blowing around the center on the top side of the plug.Also try adding a few oz.of 2 stroke oil to the fuel to see if you have a valve making noise from carbon that will form in the stem of the valve when the guides are a little worn.
Old 11-04-2014, 11:24 AM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
Thank you for the responses.
Old 11-18-2014, 07:21 AM
extip123's Avatar
extip123
extip123 is offline
When the compensator was off did they also check the teeth on rotor on stator? I had similar problem with strange sound. Primary oil was clear without any shawings?
Old 11-18-2014, 11:12 AM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
I guess I don't know that. Will take the advice and check it when I start teardown. Thank you.
Old 11-21-2014, 12:08 PM
SilverEagle50's Avatar
SilverEagle50
SilverEagle50 is offline
Ohio, is there any update on your problem yet?
Old 11-21-2014, 02:38 PM
Inop's Avatar
Inop
Inop is offline
Wild guess here, could it possibly be your belt......how fast were you going? how old is the belt?
Old 11-23-2014, 08:45 AM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
I have no update yet. Because I have been through the primary and the cam chest, I think I have to tear the engine down again this winter. I am guessing it has to be the crankshaft bearing on the left side. Nothing else is spinning under all conditions except the chain and engine. I didn't do the Timken bearings in the cases when I had it apart at 10k. I had no desire to go over 100 HP or Ft Lb so didn't see the need to do the bearings. Wish I had. At the time general consensus was that if you stayed under 100/100 the stock bearings would be OK. I haven't had it dynoed but the service manager was impressed so maybe it's too strong for the stock bearings.
Old 11-27-2014, 11:02 PM
HooliganCycles's Avatar
HooliganCycles
HooliganCycles is offline
Have you tried spraying a little lube on the front stabilizer? The one that bolts to the front cylinder head and to the frame, I have had those squeak where they bolt to the frame, a little lube and the noise was gone
Quick Reply: Now what???
