Here's how to vent SE aircleaner for Softail/Dyna
Could not find any info about doing this. All the info was for the Baggers. So here is a picture of how to vent your SE aircleaner for Softail/Dyna to atmosphere and keet hot air and oil mist out of your intake. I cut off and used the stock breather hoses. I also put a thin bead of sealant across the breather hose fitting where the air filter touches it. Look close and you can see the blue sealant. Maybe not necessary but there is a chance unfiltered air could get past it. I used clear lawn mower gas hose. The hose tucks into the air filter cover without touching the air filter. Took some trial and error cutting the hose to get it just right. About 12-15 bucks for hose and fittings.
LCCXL1200X
2014-2023 Touring Models
02-06-2016 11:28 PM
