Need Help! Installing Sissy Bar Side Plates for 2015 Sportster 72
I've been looking all over the web for help on this, but was unable to find a video matched the 2015 Sportster 72's setup. It seems like the reflectors are attached to the underside of the rear fender, and in a tight enough spot that prevents removing the nuts. This consequently prevents there being enough space to slide the side plates into place and attach them. I would take it to the HD dealer..but they want $220 to install them..
Any advice on this would be greatly appreciated. I spent about 3 hours today working on this until it got dark and I had to pack it in.
So the reflector is attached to a plastic housing that connects to the underside of the fender (unlike other Sportys I've see where it's simply attached to the outside). The plastic housing seems to sheath the nut that holds on the right rear turn signal, and it's blocked from being turned.
Same issue on my 883
I'm having the same problem! My concern is now that I've successfully removed the rear strut bolts I loosened the front bolts but only enough so that the nut keeps spinning. So now I can't tighten it enough to ride to a dealer/shop for a proper install. Can I safely ride the bike with the front strut bolts that are loose?
Pickle_rick_C137
07-02-2018 09:11 PM
streetglide4567
08-07-2017 11:01 PM
