factory installed oil filter tip
after what I went through to get the oil filter off on my new FLHTPI, my tip to all new H-D DIY owners......buy the K&N or similar socket/lug type oil filter. it will make your filter removals so much easier. I could not get anything on the filter, except the HD cut out filter wrench ( cut out for primary case sensor). the filter was on so tight from the factory, that I had to use a breaker bar. since you will only use the H-D filter wrench once, pass it on to another. I was amazed how they bury the filter. i would also be curious to find out how many ft. lbs. they torque the filters on at York.
Would an old school oil filter strap wrench work? I am going to change my oil this weekend and I bought the HD filter and can already tell the oil filter socket cap I have that fits, won't get past the sensor. I am trying to spend my money wisely if I have to buy a tool to do it. I don't want to go ghetto and stab it with a screwdriver. Too much can go wrong and its just a poor practice for anything but emergencies.
car5car
Oil Archive (no new posts)
18
12-16-2009 05:25 PM
