08 Fat Bob defys logic
Old 04-19-2015, 03:50 PM
loosescrew16's Avatar
loosescrew16
loosescrew16 is offline
Stage III
Default 08 Fat Bob defys logic
Ok, had my fork leg sliders chromed. Started to put forks on and went good! Now putting on rim, notice the calpier on the right would not slide on to rotor because it was to tight to bolt holes on fork leg. On the left side it was the opposite, to much space between caliper and fork leg. I tried changing spacers by putting the bigger spacer on right side of rim and smaller spacer on left side. Now it offset the tire from center of forks. Tried a few ways with spacers back n forth and still same problem. I'm confused!!!!! Tire is back centered now , and rotation is going in the right direction. Totally stumped????? Any help would be greatly appreciated
Old 04-20-2015, 09:21 AM
enodrano's Avatar
enodrano
enodrano is offline
One important thing when having parts chromed or powdercoated is to make sure all the necessary holes are plugged ahead of time. If not the added thickness of the plating/coating will affect the clearances. You may have to tap or drill out bolt holes if they were plated. Also remember that the bolt holes are not the only issue when plating. Your entire part will be thicker. It may not be by much but it can have a great impact on machined parts with tight tolerances.
Old 04-23-2015, 11:30 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,238 Likes on 1,814 Posts
Is your "Right" & "Left" as if sitting on bike (correct way) or looking from the front?
Did you get your sliders chromed or do a chrome exchange?
Does your fender fit the mounting holes?
adamsrotors
08-21-2020 07:29 PM
chapy6767
12-21-2016 10:20 AM
sfckelley
2014-2023 Touring Models
25
10-17-2016 07:41 AM
justin_ryan
08-06-2015 08:10 AM
dawg
11-18-2007 09:06 PM
Quick Reply: 08 Fat Bob defys logic
