General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
the dealer said to use 20/50 synthetic in my tranny now instead of Harley Davidson trans fluid and now when its hot outside the bike gets hot and the tranny works like its got no lube in it shouldn't I be using a heavier fluid like 80/ 90 weight in it
To answer the question, yes you should be using a heavier gear oil in the tranny. Pick your flavor, syn or conventional, and it will smooth things out and quiet things down in your tranny.
Don't buy his/HD's BS, 20/50 syn is engine oil. It's not a gear lube, which is what should be used in a tranny. Baker Transmission use Spectro. I happen to like Redline Shockproof.
Check out Baker's website. There are several other gear lubes that will also work. Good luck.
Personally I would never put a motor oil in my transmission. I don't care if it says it's a 3 way oil. I use a 75/140 weight gear oil. You can get conventional, synthetic, or semi synthetic. Harley used to make a semi synthetic but stopped making it when sync 3 came out. In my opinion gears that are constantly meshed in an oil bath need a high viscosity gear oil.
Reason: 75/140 not 75/80
I've never run engine oil in my transmission. Ignore your dealer and follow the owners manual, at the least! I've just put Redline in my bike for the first time, but it's early days for me. We also have a separate oils section in this Tech area, where you will find endless discussion and quickly get swamped in the stuff!
