General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Silly question and I know it won't hurt. When the splines are slightly worn on the shifter shaft is it a good idea to use blue lock tite. Correct me if I'm wrong---- to remove the shifter shaft all you I have to do is remove the back 3/16 allen bolt and I believe the shaft will just slide out forward----- correct.
Loctite works with the absence air on threads when torqued, it will not have any effect on the shifter splines as they are not tight enough in tolerance to be air tight...
