Sirrus/XM won't stay activated?
Old 06-15-2015, 11:03 AM
nelson_j_m's Avatar
nelson_j_m
nelson_j_m is offline
1st Gear
Unhappy Sirrus/XM won't stay activated?
I have tried to activate Sirrus/XM twice. The first time it activated and I waited maybe 10 minutes until I could select different channels and hear them. The second time I activated and rode the bike for close to two hours listening to XM. Both times, I shut down my bike and the next time I started it I had lost the activation and XM showed unsubscribed in setup. Any ideas?
Old 06-17-2015, 08:03 AM
enodrano's Avatar
enodrano
enodrano is offline
Your satellite radio has a digital switch inside that activates or deactivates the radio service. When you activate a satellite radio the vendor updates the satellite in space with your radio ID. The satellite then sends a special signal to activate (flick the switch) your radio. That process takes 10 minutes or more. They actually send the signal occasionally over a window of time to make sure your radio can get to a place it can receive the signal. The same process happens when you deactivate. There's actually a loophole in the system because if your radio is off when they send the deactivation signal your radio will not deactivate. If you leave it off for 3 or 4 months they stop sending the signal and your radio will never deactivate.
Anyways, if your radio activates and soon deactivates I would say there is a problem with the hardware or software of the radio. You should look inot getting it replaced.
IzzoQuazzo
Audio Systems
05-26-2017 01:15 PM
merlin41
09-12-2012 11:47 PM
NO4NMTL
04-06-2011 10:32 PM
NMNSG08
03-11-2011 06:05 AM
merlin41
09-21-2010 11:50 AM
Quick Reply: Sirrus/XM won't stay activated?
