Slip On Exhaust Prolem
Old 08-10-2015, 01:27 PM
Airborne06's Avatar
Airborne06
Airborne06 is offline
Default Slip On Exhaust Prolem
Greetings!
I have an issue with my Screaming Eagle slip on exhaust pipes that is very frustrating, and quite frankly very confusing.
This morning I removed my SE Street Cannons, and tried to replace them with the slip on pipes I had on previously: SE Diffusion Disc pipes (part #80847-10).
The HD dealership removed the SE Diffusion Disc pipes about 18 months ago, boxed them up, and installed the Street Cannons. The boxed up pipes they removed have been sitting in my garage until this morning.
I removed the Street Cannons easily, and tried to slip on the SE Diffusion Disc pipes. As with every other exhaust pipe I have ever installed, the right side pipe (and sometimes left as well) has an indentation to accommodate the right side axle nut protruding outward. However, neither of the Diffusion Disc pipes had this indentation. So...I guessed that perhaps one of the pipes was narrower than the other. I was wrong...they are identical.
I attempted to install each pipe on the right side, but they each contacted the axle nut. I can't see how they would slip on without the indentation.
SO...either I am totally inept (it's possible, but I have removed/installed countless pipes over the years), or the dealership mixed my pipes up with others they may have had, and gave me two left pipes that don't have the indentation.
Hopefully someone out there has these pipes and can tell me if there is, in fact, and indentation on the right side pipe...or can tell me what I am doing wrong.
Wanted to check here first before I go to the dealership and make some wild allegation that they will likely deny anyway.
Thanks in advance and best regards! A06
P.S. Ignore the title misspelling...it should be "PROBLEM", not "PROLEM"!
Old 08-11-2015, 06:37 AM
enodrano's Avatar
enodrano
enodrano is offline
The way to tell if you have two right sides or two left sides is by the Screaming Eagle logo etched on the slip-on. They should be opposite each other on a right and left slip-on. That is unless they etched the logo on each side.
Also, I wouldn't think the dealer would have a bunch of SE Diffusion's sitting around to mix and match, but I've heard of dealers doing some strange things before.
Another thought, are you using a motorcycle jack? If so maybe the dropped axle is causing your issue.
Airborne06
08-11-2015 11:18 AM
blackpullet
01-23-2012 09:22 PM
Dudleyglide
Exhaust System Topics
01-02-2009 10:48 PM
PWFD
05-25-2008 11:14 PM
Quick Reply: Slip On Exhaust Prolem
