Front tire wear
Front tire wear
Ok tire experts, here is the problem. I have an 07 Fatboy running Michelin Commander II's front and rear. The front tire is way more worn on the right side (sitting on the bike) than on the left side. Bike does not appear to be out of alignment, as it tracks straight and true. Recently returned from riding about 1200 miles in the Smoky Mountains. Is it possible that I just lean more on the right side? Up in the mountains there is no such thing as a straight road.
Just wonder what else may have caused the uneven wear....
Get your alignment checked.
You might also want to check the fork tubes where they stick up through the top tree that they're even. Might be that one side the clamps have come loose or are just adjusted incorrectly.
I've never seen it do that on a Harley, but on *many* rice-burners I have seen it...and no, it's not because of a crown in the road, the 'crown' and subsequent angle of the road going from the crown to the side of the road would have to be outrageously crazy of an angle, one that would make one think you were on the side of a steep mountain in a jeep.
the 07 FB has an offset on the front end due to the companies haste to get the 200 rear end out. a closer look will show it, the reason the cow bells are cutout on the inside. it was corrected in 08. 07 is a mutt, search the forum, lots to read about it
Thanks for the replies. I will check out the alignment and the fork protrusion through the triple tree...I am well aware of the "Red headed step child" nature of my 07 Fatboy...I bought it new. It does have the weird "not centered in the fork" front end. This has always bugged me, but has not caused abnormal tire wear in the past. I switched to Michelin Commander II's both front and rear. So far (about 12-14k miles) the rear has held up way better than the Dunlop tire it replaced. The front has worn out faster than the Dunlop front tire. Hope I can figure it out...
