Swapped out speedometer to see what it looked like on bike...
Didn't ride it at all with it in, but did hook it up to bike and powered it up. Would it have caused any issues with my ECM in anyway?? My **** won't start now after doing this and thinking I need to reset or clear the ECM. Or??? Anyone to help??
Bike is an 02 Softail Deuce
I probably should have posted this in the ECM sub category, can an admin move it for me please? Or delete and I'll repost??
Hey monkey, good timing...maybe You might try here. https://www.hdforums.com/forum/dyna-...crewed-up.html
Focus on post#6
It worked for him. He was changing the ECM, but it does say...
"Once you remove a component from this chain the module shuts down and won’t start."
You are going to end up here
http://www.harley-performance.com/password-learn.html
Focus on post#6
Hey monkey, good timing...maybe You might try here. https://www.hdforums.com/forum/dyna-...crewed-up.html Focus on post#6 It worked for him. He was changing the ECM, but it does say... "Once you remove a component from this chain the module shuts down and wont start." You are going to end up here http://www.harley-performance.com/password-learn.html
I found the info last night and was going to try it this morning
Pisses me off, like why didn't this happen when it was pouring outside and I didn't care.
Now it's 75 degrees outside and my bike is in tee garage!!
Just had the 95 kit installed with SE 204 cams, ready to roll....NOT!
Thanks for response though
How are you man?
I'm questioning if I even have to go through all this.
I know many have swapped out the speedometer on their bike, and would think some wouldn't of having to go through these steps....
I "hear" ya brother...just wanted to make you aware.
Personally, if it happened to me...it would have been my "First Rodeo"
