How disassemble Police Hockey saddlebag
I've repainted mine and dismantling the pucks was easy. Check on-line here, where you can see the components that make up the pucks and latches. I left all the rivetted metal brackets on and my painter painted around them. I did buy new #79048-98 latch seals, the self-adhesive foam rings that fit around the puck spindles. I'm pleased with the end results:
The hockey puck is integral with the spindle that goes down through the lid. On the inside of the lid, remove the 'D' shaped thick wire latch. Pull on it until it detaches from the spindle. It looks a bit intimidating, but as Captain Itch suggests, a bit of brute force will win the day. It might be an idea to take photos, so you can see what they looked like before you dismantled them!
overdrive
11-21-2010 09:18 AM
