Cruising vibration
Old 05-25-2016, 10:01 PM
popeye40's Avatar
popeye40
popeye40 is offline
2nd Gear
Default Cruising vibration
SO I just got a 94 Dyna Can I balance the front wheel my self . Or do I have to bring it to my local shop .I feel a vibration at cursing speeds maybe around 40 . the guy I got the bike from said his brother in law ran into the back of his sister in law bent the forks and he replaced all the bent parts but I wanted to check the front wheel for balance and maybe even trueness .
Old 05-29-2016, 09:25 PM
83hdfxrs's Avatar
83hdfxrs
83hdfxrs is offline
They have a machine that spins the tire and tells you where to put the weights at and how much weight to add. I would have a shop test the tire, and rebalance it if necessary. I had a bike that one of the weights fell off and the bike vibrated like hell.
Old 05-29-2016, 10:24 PM
popeye40's Avatar
popeye40
popeye40 is offline
2nd Gear
This is my first Harley and after reading a bunch of posts on Dayna vibrations I think mine is solved
Old 05-31-2016, 06:20 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
You can balance a front wheel yourself, if you want to, although it is simpler in a balance machine.
Old 05-31-2016, 08:48 AM
popeye40's Avatar
popeye40
popeye40 is offline
2nd Gear
I see the balancers on ebay but why cant I just jack the bike up unbolt my brake caliper so I have no drag and do the same thing with out having to take the wheel off.
Old 05-31-2016, 09:11 AM
grbrown's Avatar
grbrown
grbrown is offline
Thumbs up
You can do exactly that! The technique is to rotate the wheel slowly, so it turns over say one revolution and mark where it stops. Repeat several times, to see if it stops in the same place, when you can add a weight on the opposite rim. Then repeat until it never stops in the same place.
esteboatan (06-11-2016)
Old 06-05-2016, 11:31 AM
roussfam's Avatar
roussfam
roussfam is offline
Received 6,742 Likes on 3,509 Posts
Let us know if you get rid of the vibration. I'm a pessimist, when I hear somebody hit something bad enough to bend the forks but the fixed everything themselves.... Then why are they selling the bike?
2018FatBob
07-22-2018 03:48 PM
DakotaYota
03-03-2014 01:31 PM
Mr.Twisted
06-02-2012 01:42 AM
hoethree
08-25-2010 11:25 AM
azfathog17
09-27-2008 08:14 AM
Quick Reply: Cruising vibration
