Can you check brake rotors for true with a stright edge?
Just wondering if using a straight edge and feeler gauges is an accurate enough method for checking brake rotors for warping. I dont have a dial indicator and using a pointer and spinning the wheel doesnt seem to be that accurate either.
Answered my own question. Took a 5 gal bucket. Put the straight edge on top with a weight on it and ran it parallel to the rotor. Pushed it in to the outside 1 inch of the rotor and made sure it was square and touching the rotor. Very slowly turned the wheel and kept a 5 thou feeler gauge on top. In a couple of places the 5 went in snug but a 6 was a no go. Not as accurate as a dial indicator I am sure. But I am comfortable that it wasnt far enough off to matter. The spec is 8 thousanths.
If your getting any front end shimmy, if its front your working on I would replace. Have found the front single rotor slightly tweeked on a heritage with just 20k on the bike. Rears don't usually bother, at least so you would notice, just replace pads before they get into the rotor and ride it!
It is a hand full to align things and get tire and wheel into place. I have taken a small piece of plastic tubing that fits over the brake bleeder, run to a can, just crack open the bleeder enough to push the caliper piston back. This should allow you enough extra clearance making the instal a bit less of a struggle. Good time to consider if brake fluid should be changed as well. Caution, you may have to bleed system when opening bleeder to be sure of no air in the system when everything is in place. Be sure if doing that to use the recommended brake fluid for your bike.
martin10 (06-15-2016)
Sounds like you got it. That's great!
