'11/'15 Dyna cable compatibility
Exactly what the title suggests: I'm trading my apes and 14" cables for OEM cables, but want to make sure my buddy's 2015 OEM cables will connect to my 2011 Dyna. Both are Street Bobs, pretty sure no ABS on either (definitely not on mine.) Of course, Harley won't tell me anything.
Hi Rob, you can check part compatability by looking at part numbers on-line here. If the #s are the same you have your answer. If not I suggest you post in the Dyna section, where you should get a better response.
bigtexasrob (07-28-2016)
Thanks, that's a super helpful resource. So that the information is out there, yes, the cables are the same as verified by part numbers. This includes clutch, front brake, idle and throttle cables for the 2011 and 2015 non-ABS model Dynas.
Hopefully I'll have some less-show more-go bars on this beast soon.
